Forums/Z31P/z31-repairs-forums driveline/84 300ZX Turbo Tranmission upgrade to FS5R30A
Imported from Z31Performance.com Forums{{#if:Jeshore| — original post by Jeshore}}{{#if:2018-01-08 17:18:54|, posted 2018-01-08 17:18:54}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/538340-84-300zx-turbo-tranmission-upgrade-to-fs5r30a.html|
Jeshore: (2018-01-08 17:18:54)
Hello all,
I'm in the middle of replacing my clutch and was wondering if anyone had swapped in the FS5R30A to an '84? If so what complications/modifications did you have? I've seen mention that the bell housing are the same bolt pattern but no other specifics.
mwolvinm: (2018-01-08 17:30:13)
If I remember correctly.... different driveshaft, and the transmission mount may not line up with existing holes in the body.
daniel_pearce: (2018-01-12 01:13:56)
The FS5R90A and FS5R90A have different driveshaft configurations and differential companion flanges. The diameter length and diameter of the slip yokes are also different. From what I understand, you'll need to swap differential companion flanges on the differential with a steering wheel puller. Not sure if the same applies when doing automatic to manual conversion which is what I will be doing.
Full list of details and schematics here:
https://z31library.com/xenonzcar_archive/z31/Driveshaftinfo.html
