Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Will these wheels fit ???
Imported from Z31Performance.com Forums{{#if:NewJerseyZ| — original post by NewJerseyZ}}{{#if:2018-04-30 00:39:36|, posted 2018-04-30 00:39:36}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/539410-will-these-wheels-fit.html|
NewJerseyZ: (2018-04-30 00:39:36)
A friend of mine keeps trying to help me get better tires and brakes for my modified 1985 Z31 Turbo. Although I appreciate his efforts and understand that better handling and brakes are a nice addition to having more power, I'm not quite sure that what he's suggesting will fit. He's suggesting 8" wide Enkei PF01 17 inch with 235/45/17 tires. I personally don't think I have the inner clearance, but perhaps some here might know what my limits are with wider/taller wheels. Thank you.
FlawleZ: (2018-04-30 17:37:04)
What's the offset and bolt pattern? Most 5x114 wheels fit our cars, but most have positive offsets which sink deep into the fenders due to our cars running a low offset stock.
Dunkine: (2018-04-30 23:54:44)
Check out https://z31library.com/extras_archive/www.thezenthusiast.com/wheelshow.html
Has the factory specs and you can look at what others have run.
You could run spacers for those or just get wheels with the right offset.
areebashar.23: (2018-05-10 19:17:01)
If you get spacers try and get hub centric ones.
