Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Turbo crossmember differences?
Imported from Z31Performance.com Forums{{#if:cmgreen22| — original post by cmgreen22}}{{#if:2014-05-06 17:37:50|, posted 2014-05-06 17:37:50}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23727-turbo-crossmember-differences.html|
cmgreen22: (2014-05-06 17:37:50)
Courtesy Nissan has their turbo crossmembers under different part numbers. 84-86 turbo crossmember and 87-89 turbo crossmembers. Can someone with knowledge on this tell me the differences. Before I discovered this I assumed they were all the same. Thanks
Augustus Maximus: (2014-05-06 20:23:49)
The only difference I'm aware of is the 84-86 has wider (more desired) PS bracket on the driver side.
https://z31library.com/external_images/www.garymolitor.com/300zx/SRB-Information1.pdf
jaqattack02: (2014-05-07 02:48:17)
I thought the only part that was different was the strap/hold down bracket? I didn't think the actual crossmember was different.
Axel kain: (2014-05-07 13:38:38)
^bolt hole size difference I believe for the PS brackets.
