Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Question about watanabe wheel fitment
Imported from Z31Performance.com Forums{{#if:Daimon| — original post by Daimon}}{{#if:2016-01-08 21:48:42|, posted 2016-01-08 21:48:42}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/25532-question-about-watanabe-wheel-fitment.html|
Daimon: (2016-01-08 21:48:42)
Hi, i project to buy a set of rs watanabe this year,
but im little lost, dont know if it will fit or not.
On the watanabe official site, they show somes configurations, i would like to know if it will fit on my 84 300zx
I can see :
- F: R16-80 ±0 R: R16-85 -6 5
https://z31library.com/extras_archive/www.rs-watanabe.co.jp/
apparently this configuration fit well on my 84 model
- F:R16-85 -6 R:R16-90 -13 (or -19)
And we have this config with more offset, it look better, but i m not sure if it will fit on a zenki model
Can i put a -6 offset on the front wheel on a 84zenki model ?
thank for advance for the help
Daimon: (2016-01-09 00:48:18)
i know this site ,but i'm not sure i understand it well, look like nothing fit on this list.
any personal experience ?
Daimon: (2016-01-09 22:46:20)
I reformulate , how many offset have you put on your car ?? 0 offset is the max or i can put more on the front ?
Pace: (2016-01-10 00:37:29)
Try using an offset calculator like this one.
https://www.1010tires.com/Tools/Whee…et-Calculator#
It will tell you how much further the new wheels will extend inward/outward. From the numbers given, measure to see how that will compare to the wheels currently on your car. That will give you a better idea of what will fit.
In my opinion, the 16x8 +0 and 16x8.6 -6 setup matches the narrow fender Z31s well.
frostvectron: (2016-01-12 17:19:55)
Are you willing to roll/pull your fenders? Are you going to stretch tire or not?
adamvann3: (2016-01-13 22:59:11)
16x9 +15 w/ 225/50 BFG Rivals
15mm spacer up front = effective +0
s13 rear subframe in rear = effective +5
Running -2.5* camber all around with rolled fenders
A lot of your wheel width and offset also deal with your suspension setup
Daimon: (2016-01-28 23:47:03)
hi, sorry for the late answer,
nothing is done for the moment, suspensions are stock.
i want to put bilstein B6 this year, if necessary, i 'll roll my fenders
Thanks for you answers guys, i think i'll go 0 offest on the front .
