Forums/Z31P/z31-performance-upgrade-forums engine-management/NisTune Info (link)
Imported from Z31Performance.com Forums{{#if:Jason84NA2T| — original post by Jason84NA2T}}{{#if:2006-08-15 19:39:07|, posted 2006-08-15 19:39:07}}{{#if:212| · 212 post{{#ifeq:212|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/610-nistune-info-link.html|
Jason84NA2T: (2006-08-15 19:39:07)
This has been posted on other forums, so I figure it's about time to post it here.
I will say this once:
DO NOT send e-mails to Matt with questions about his product before asking here. If you want to know something that is not clearly covered on this page, post your questions here and we will gladly answer them for you! Don't make yourself look like an idiot! Basically what we dont want to happen is for Matt himself to get flooded with a bunch of simple questions that we can easily answer for him.
https://z31library.com/extras_archive/www.nistune.com/
G-E: (2006-08-16 02:12:29)
which is the one that doesn't need romulator to edit?
or does v2 not allow editing?
Stinky: (2006-08-16 13:00:17)
Rev 2 can use either an nvram chip or a romulator. If you decided to go with the nvram I would suggest waiting for rev3 as it will have the nvram built in instead of having to buy it and program it yourself. All nistune versions will provide realtime editing unless you choose not to install nvram or a romulator. I think rev3 comes with nvram by default.
Firehawk: (2006-08-18 07:23:32)
a little explanation requested, is a Willem programmer needed for each board, or can one do many?
G-E: (2006-08-18 13:45:19)
the willem is a chip burner.... you can burn bmw roms or pc bios chips with it
MikeZ: (2006-08-24 21:19:03)
I really don't think that you should take it to heart like that. It was just a suggestion to keep the producer of the software from getting bombarded with questions that can be answered by people with first hand experience already using the product. It would make sense to ask the questions here as well, since you will be adapting the software to the z31.
Stinky: (2006-08-25 00:48:12)
The post could be worded better. Basically what we dont want to happen is for Matt to get flooded with a bunch of questions that we can easily answer for him.
To answer your question I have no doubt that m30 support will work. The m30 uses the same 6303 cpu as the z32 and other ecus. I think at this point its a matter of finalizing the board design for the 6303 ecus and doing testing. The m30 code will need to be modified just like the z32 code so that it works with the extra Nistune functions. That should be a trivial task for Matt unless something stupid comes up. Unfortunately someone with an m30 ecu will need to try it out before anyone can actually gaurantee you that it works. If you are willing to be a guine pig then you can try contacting matt.
simply86T: (2006-09-01 19:19:01)
How is nvram going to come by default?
I solder this:
onto this:
then place this nvram:
[archived image: 42268255.jpg]
on top of this:
Also, Matt reply my email saying he will do the installation for $40 if I send him my ECU. So I kind of see this as a fairly final version......
In addition, the Willem Programer will only be used to extract the stock rom image right? Because this Nistune board will already be plugged into laptop directly using USB.
Jason84NA2T: (2006-09-01 20:04:17)
You won't have to solder, the board and NVRAM just push into place the same as any ROM chip.
The programmer (chip burner) would only be needed if you wanted to burn a new base image on the NVRAM chip, or burn an ordinary PROM chip to put in place on the ECU when you have "completed" a tune.
simply86T: (2006-09-01 20:56:59)
Hmm...... here is the reply I got from Matt:
To install the boards
1. You need to remove the two factory ROM chips and
four jumpers and a resistor
2. Read the ROM chips and program the board (using a
Willem programmer in NVRAM mode)
3. Install a 28 pin machine drilled socket and install
four new jumpers
4. Solder a 4 wire connector to the 6802 CPU legs
5. Remove the factory adjustment pot and put the USB
connector in the bracket
6. Put the board in the ECU, plug in the connectors,
hot glue and reinstall into the vehicle
Some installation instructions are available. I've
taken pictures during my last install.
It will be $10AUD postage and handing for the board.
However if you want I can perform the installation
procedure here, if you send the ECU. It would be
instead $40AUD return postage
cheers
Matt
Was the soldering he mentioned referring to his own Nistune board and not to stock ECU?
So I guess a programmer isn't really necessary, if the new tune image won't be erased when I unplug the laptop right?
Stinky: (2006-09-01 23:01:18)
There are a few wires that need to be soldered between the nistune board and the stock ecu.
Here's the deal with the nvram. Currently the nvram chip is a standard 28pin chip which can be put in the willem programmer and programmed with a few special steps. Once the base image (stock bin modified with the nistune code) is programmed on to the nvram chip it is put on to the nistune board. At this point nistune is able to alter only certain allowed addresses on the nvram which are used to tune. The base code itself is protected so you dont accidentally screw something up. If the base code of the nvram chip becomes corrupt the only way to fix it is with a willem programmer. Also, if you decide to change base code for some reason you must use a willem programmer to do so.
It's my understanding that the final nistune board design, which I'm guessing most people will end up with, will use a surface mount version of the nvram which is not removable. A special adapter will most likely be required to program the nvram with the base code.
When all is said and done I think it will work like this. When you buy nistune you will need to choose a base code for you ecu (84t, 88na, 88t, jwt, whatever). Matt will keep a collection of common base codes or if you have an odd ball you can send him your chip or a bin file of it and he can modify it for nistune. Anyway, the base code will be programmed on to the nistune board by Matt of whoever is selling the board. You will install the preprogrammed nistune board in your ecu, make any required tuning changes, and away you go. No need for a willem programmer.
OK85ZX: (2006-09-02 16:31:42)
Okay so just to clarify. Once that version comes out, will we need anything to be able to tune it other than a USB cable, laptop, and the software?
Jason84NA2T: (2006-09-02 21:20:49)
aside for the actual install work, 100% Correct.
OK85ZX: (2006-09-03 19:28:00)
sounds awesome. I'll be in for one as soon as that version comes out.
  • goes searching for a laptop*
Any future plans for palm pilot support?
84z31: (2006-09-03 19:32:25)
i just paid off my desk top computer yesterday. sounds like its time to step up to the lab top. i can't wait to get the nistune for my car. i'm very excited for this setup. and you simply cannot beat the price. i hope the guy is making a few dollars off it.
FlawleZ: (2006-09-04 01:09:01)
I don't think he has disclosed a price on the final product yet.
OK85ZX: (2006-09-04 09:10:24)
are there any system requirements for the computer or will it basically be able to use anything? also, is it a windows program or dos? Just for verification… what specific year/trim ECU's will we be able to use with it?
84z31: (2006-09-04 13:29:08)
any year computer will work. the older ones take more work to get them to work.
i think i've heard that you will need window XP pro. someone else might be able to confirm that thou.
Steve88t: (2006-09-04 15:11:28)
If you need XP Pro, how can you use any year computer. M$ puts checks in the install process to prevent you from doing shit like that.
OK: any laptop that will run XP will work fine. I use a Celeron 600 with 128mb ram to run XP Pro for all my car stuff. It is cheap and small so I dont care about it.
  • edit* Oops I misread the statement. He was refering to any year ecu not any year laptop. Yes any year ecu will work fine.
Kennedy: (2006-09-04 20:23:44)
That only slows down install process.. not stop it :wink:
84z31: (2006-09-04 23:43:55)
any Z31 computer.
for a labtop i think it says you need XP pro.
OK85ZX: (2006-09-05 06:31:24)
can someone who knows first hand confirm which year ECU's are compatible with NisTune?
Bernardd: (2006-09-05 12:42:17)
Jason84NA2T: (2006-09-05 13:48:48)
Did he manage to solve the small issue that was reported with the early 87 ecu's yet?
ZDaddy: (2006-09-05 15:14:36)
This is probably a really stupid question…but does the base code that I choose have to match the ECU I have?
For example…Do I have to ask for the 86NA base code if I'm using an 86NA ECU or can I just ask for an 88T base code or will that not work with the 86NA ECU?
Stinky: (2006-09-05 16:40:01)
The base code will need to match the ecu hardware. For the most part that means you have to stick with the stock bin that your ecu came with. 86 and 88 are different but 88 and 89 are the same. In some cases you can mix them up between turbo/na and 5spd/auto depending on what features you want and if you make certain modifications to the ecu hardware.
Firehawk: (2006-09-05 19:02:18)
is there any benefit to using the 88 ecu with the 16bit hardware?
84z31: (2006-09-05 19:59:38)
its faster then the older ones and has a better fuel map.
ZDaddy: (2006-09-05 20:16:10)
How did you get yours? I know others have it too....how much did you guys pay?
From what I gathered, it isnt available? When will it be?
When I look on the website it seems as if I could (and should) order one right away.
OK85ZX: (2006-09-05 21:51:55)
A few members of the community grabbed the beta version of the board/software to try/test it out.
OR-Zman: (2006-09-06 02:08:26)
Yep, and unfortunately I am several months from being able to use my 84NA Nistune ECU. [archived image: frown.png]
Matt used to have the price on the site. Apparently he is considering some pricing changes?
Bernardd: (2006-09-06 13:35:06)
Lance: (2006-09-06 14:07:19)
[quote]Bernardd wrote:
{{#if:Firehawk|Firehawk wrote:|Quote:}}
i'm not aware of any 16 bit z31 ecu. the sr20/ka24de ecu's are 16bit and require daughterboards. all the processors in the ecu's are the same. the newer ecu's have newer components but that doesn't necessarily make them better. didn't someone post a dyno sheet of a 84 ecu vs the 88 ecu on the same engine where the 84 tune was better? i would think as soon as you tune either it wouldn't matter anyway.
The 88-89's have a 16 bit eeprom setup that's easier to tune yet the factory tune is inferior to the previous years' ECUs because it's setup for the smaller t25 turbo.
Steve88t: (2006-09-06 14:54:07)
Since this seems to be a fact in question, where did you get that information. I consider what Bernard says on this subject to be near proof considering his experience. So if you disagree, I'd love to see where you got that info.
Lance: (2006-09-06 15:06:38)
[quote]Steve88t wrote:
{{#if:Lance|Lance wrote:|Quote:}}
JWT… but I guess considering their record it could be wrong
Bernardd: (2006-09-06 16:55:03)
280Z Turbo: (2006-09-08 01:39:48)
So if I wanted to use Nistune there would be no actual performance advantage for me to use an 88-89 N/A ECU in place of my 84 Turbo ECU?
simply86T: (2006-09-08 14:14:54)
[quote]FlawleZ wrote:
{{#if:84z31|84z31 wrote:|Quote:}}
Price is AUD$300, which is about USD$230, S&H not included. This is from Matt's email about a month ago.
Steve88t: (2006-09-08 15:25:54)
Considering the alternatives, that isn't a bad price. This is only the second advancement for z31 ecu's since jwt started selling his shit O-so-many years ago. I think when they become publicaly available a BUNCH of you should buy them. I will.....
Jason84NA2T: (2006-09-08 15:54:28)
I'm not at all sure how to alter the voltage circuit on the earlier (pre 88) ECU's to allow maf/VQmap changes away from the stock MAF. I'm sure someone has or will figure that out though.
ZDaddy: (2006-09-08 20:05:20)
Count me in. Heck, the market going rate for the 88T/NA ecu is around $130. One guy on Z31.com told me he wanted $200 for it. And thats just the ECU, forget about all the other Romulator costs on top of that. Yes, $230 for the whole package is nice and reasonable…I'll start saving for it now.
grahfz: (2006-09-13 01:41:15)
[quote]Jason84NA2T wrote:
{{#if:280Z Turbo|280Z Turbo wrote:|Quote:}}
what about figuring out a way to signal boost regular MAF signals the 2v or so.
I'm talking about bringing the "normal" 0-5v signal to 2-7v's like the ecu's expecting.
In theory, that would get you around having to find the resistors to cut out.
Bernardd: (2006-09-23 12:26:18)
darkhalf: (2006-09-28 12:15:44)
hey guys
just joined up. bernard forwarded me the link to this page. just to let you know what the deal is with the boards
the current version of boards (rev b) as pictured on the website require a pocket romulator and will work in 1986-1989 Z31 ecus.
i dont think there are any Z31 ecus I can't do. Also I'm not aware of any 16 bit Z31 ecus. the 16 bit ECUs started happening when JECS moved to the MELPS processors after Hitachi got sued by Motorola for ripping off the 6802/6303 processors used in Z31/Z32 ecus. hence only late model Z32 ecus are 16 bit.
these revb boards are the $300AUD mark with the software and installation instructions. i have about six of these left.
currently support three different wideband units (zeitronix, techedge and innovate)
the software should run on any PC. it was written for small size and high speed
was orignally developed on Win98 and still runs this on a daily basis on my test bitch P266 Compaq Laptop with 64MB RAM. It could probably even run on slower machines since the most cpu intensive thing is the logging part of it. It can also run on Windows XP as that is my other dev machine
The revb board itself provides a communiations interface to the ecu to let us read the engine parameters (implementing a consult interface). using a romulator lets you tune in realtime. when you are done, you need to burn an eprom afterwards with the tune
The next generation of boards (revc/revd) in testing are NVRAM based. this means no external emulator (like pocket romulator) is required. you just plug the board in to a socket where the ROM used to sit, solder up 4 wires to the CPU and put in the USB port where the diagnostics connector normally sits and reinstall the ecu
This means you can just plug in the USB connector when you wish, and monitor or change in realtime parameters on the ECU. when you are happy with the changes you 'burn' them and less than 0.01 seconds later they are saved. You can do all this in realtime with the engine running, unlike other products out there for nissans. It pretty much works but I need to get it all checked before i get a batch of them made up. Those will be about a month or so off depending how much free time I get :wink:
cheers
Matt
bemis: (2006-09-28 13:12:05)
I've figured out how to change the Timing and Fuel Maps on my 84T ECCS.
I've also figured out how to convert it over to use the 28DIP EEPROM, just haven't worked on it enough to figure out all the new address's.
As far as the voltage circuit on the MAS, it's easy. It's a voltage divider (scaler), just like the later models.
VG36ET: (2006-10-16 03:34:16)
I'd love this for my 94 N/A VG30E Pathfinder. I'm not going to send JWT 600+ for a shelf tuned ECU that I can't change without sending them my ECU again(and more of my money). I'd rather just buy the Greedy Ultimate E-manage.
I'm gonna seriously consider this if somone tells me definitively that it will work with the above.
Thanks
Dan-TSS: (2006-10-16 22:23:20)
My lovely "Adelphia" e-mail is down(down now for the whole day) and I am looking to get in touch with mat for assistance with some simple issues I am having with connecting to the ecu....
I went to the support forum, but It seems like everything else..is very new and un-occupied.
Anyone know what I should do or how to communicate with Matt w/o e-mail?
  • My neighbor/computer guru is leaving tommorow am for 6 weeks, and I'd like to get these little things sorted before I loose my assistance and knowledgeable neighbor. Figuring these issues out with-out him here will take even longer....
8)
Jason84NA2T: (2006-10-16 22:52:15)
I believe he was working on a pathfinder version…
Lee at LP Performance said he has a romulator running on his pathy just fine.
Stinky: (2006-10-17 00:02:49)
To those of you who have/will sign up on the Nistune user forum. The forum is locked down until your username gets activated. Matt is currently in charge of activations and sometimes takes a little while to get to them. If you don't get activated within a week or so email nistunforum_at_ibconceptions.com and i'll try to get things going. The nistune forum is the best place ot ask Matt questions because all the users can learn from the post.
ZDaddy: (2006-10-17 02:34:31)
I thought it was exclusive for owners of Nistune....am I mistaken?
Stinky: (2006-10-17 02:47:53)
Yes, at this point it is exclusive to owners. I figured I'd post it here since many of you are/will be owners.
Z_Karma: (2006-10-19 22:03:36)
OK, so the +88 z31 ecus are not 16bit.
If i were to buy the current revb, i'd need an 88na ECU for my 84T, ala: http://www.redz31.com/pages/fuel/ecucompatibility.html
But, if i wait for the revc/revd i would just retain my 84T ECU, correct?
Thanks, and i apologise for the redundancy.
OK85ZX: (2006-11-08 11:31:40)
Any word on Rev3 yet? Christmas maybe? [archived image: smile.png]
Lance: (2006-11-08 16:07:46)
i'm on the waiting list for rev 3 and he told me he'd let me know. but nothing yet.
G-E: (2006-11-12 08:36:49)
I think you "learned" the wrong lesson in this thread, the older ecus just need more modifying to work and has nothing to do with nistune version
wilson101: (2006-11-15 18:13:45)
questions:
1.So is the revc/d board is going to compeletly replace the ROM with the NVRAM board.So the base tune will be programed on the NVRAM.
Or are you going to keep a non-writable ROM and have the changes done in the nvram respone to the engine?
Or is the board going to acutally flash the stock ecu rom?
2. Is the wideband dataloging going to be from a output like the innovate lm1 or can it be from directly from the wideband 02 sensor to the ecu?(im assuming it will be a output from the lm1 interface unit)
CAG8OR: (2007-01-17 00:23:20)
Is the revision 3 project dead? I have not seen any information posted to the site since september of last year.
darkhalf: (2007-01-21 07:05:52)
Rev3 has turned into Rev3A and parts have arrived, just waiting for 11 x PCBs now and then can build them
I have 7 boards assigned to people and about 20 people on an email notification list. The project is not dead, I am just doing a lot of fixes and improvements to the whole project. Please be aware that not only Z31s will be supported but the entire range of Nissans from 1984-1995 with a range of 5 different boards so there is plenty keeping us busy in the meantime.
Fortunately Z31 owners are the first people on the list to get boards since these have been 'field tested' for quite some time now. Contents of the forums are currently mainly discussing field testing results so only current owners have registration enabled. This will be opened once field testing is completed for all boards
-matt
darkhalf: (2007-02-11 09:51:54)
email me mailto:darkhalf501@yahoo.com
currently all boards are accounted for. i can add you to a waiting list for the next batch. we are currently switching manufacutrers with the nvram part for the next batch. no changes in operation however
matt
zed-031: (2007-02-19 22:03:56)
Couple of questions about Nistune. Are these able to run any upgraded injector or just the stockies and is it MAF or MAP sensor?
Cheers
Matt
mmw: (2007-02-20 01:24:10)
Questions about next batch of boards
If I understand correctly (PLEASE CORRECT ME IF I’M WRONG)
1. the next hardware is NVRAM
2. you can make changes real time
3. you can log data including data from wideband such as Innovate
4. you can save changes in your tune
With the new hardware boards, Can you
1. use a 1988 NA ECU for an 84 Turbo car (such as would be the case for JWT)?
2. use a FORD AFM (as with JWT)?
3. put tune saved with Nistune on a ROM chip & remove the Nistune board if you have a chip burner?
4. use the Nistune hardware on various ECU’s (1988 NA or 1988 T) or are you only allowed to select 1 choice (1 base tune) and stay with that.
5. Do you need to have your computer connected to the board to log data?
Thanks,
Mark
Stinky: (2007-02-20 02:48:21)
I can tell you that 1-4 on your first section is all true.
As far as the second section. 1 and 2 are true if you know what youre doing. 3 will probably be true. 4 depends on whether or not you can build the reprogrammer to reflash the base bin on the nistune board. Yes, you will need your computer hooked up to the ecu to log any data.
FlawleZ: (2007-02-20 02:58:09)
Re: Questions about next batch of boards
This would be easily answered as the board will not have active storage for logging. The storage data will be sent and recorded to a computer.
mmw: (2007-02-20 22:30:44)
Thanks for the info.
Is knowing that the 88 NA and 88 T ECU's utilize different O2 sensors enough?
Is knowing the Ford MAF outputs a voltage vs. air flow enough for question 2?
The reason I asked questions 3 & 4 is that I have an 84 Turbo and an 86 Turbo and would like to use this device on both using an 88 NA or 88 T, respectively, as suggested by JWT. I already have the Ford AFM's, resistors and injectors.
Is Matt the only person that can tell me the answers to 3 & 4?
Thanks again.
Mark
Steve88t: (2007-02-20 23:55:39)
You have a lot of reading to do. These questions are answered both on this site and on the Nistune link Jason provided in the first post. You could also use google to find more information should you feel like it.
darkhalf: (2007-03-05 13:13:24)
yep we have a design for a programmer to work with all our boards (8 and 16 bit types) to allow users to reprogram for different ecus. not available yet… just need to get the prototype made up to check it works
however currently we use a modified Willem PCB3B programmer to program the current boards using NTProg available from the download page
for example you set the reprogram jumper, and can put a CA18 ROM image instead of Z31 ROM if you really wanted
Chris86NA2T: (2007-03-05 20:46:58)
so with the currently available version of nistune and a willem programmer i would be able to load different roms onto the board? as of right now the only downside i found with nistune is that you required a base rom to load onto the board before shipping. this would make nistune very very valuable to me.
Jason84NA2T: (2007-03-06 06:58:55)
[quote]Chris86NA2T wrote:
{{#if:darkhalf|darkhalf wrote:|Quote:}}
Chris… I dont really understand… are you planning on putting the nistune daughterboard into another ECU?
Chris86NA2T: (2007-03-06 20:10:58)
yea, thats exactly what i want to be able to do.
mmw: (2007-03-08 05:18:28)
Are any changes of the Nistune ROM needed for all Z31 ECU's?
Does anyone know the answers to the following questions?
1. Would the base coding of the Nistune ROM have to be changed if one first used it in a 1988 NA ECU and then decided to use it in a 1988 Turbo ECU instead? (In other words, is there only One Nistune ROM image for all Z31 ECU's?)
2. The screen shots of the software seem to have an options Menu for AFM.
What are all the available choices for AFM (stock AFM, Z32 AFM, 93 Ford Cobra AFM)?
3. After refining the tune of a car with Nistune, can the tune be written to a chip with a chip burner, so one could remove the Nistune unit and put it in another car?
Thanks in Advance,
Mark
Chris86NA2T: (2007-03-08 07:37:39)
Re: Are any changes of the Nistune ROM needed for all Z31 EC
im sure that this is a touchy subject. im interested in the same functionality. currently i have a romulator and a willem that i use between the 3 vehicles i regularly tune, 2 of them are z31's, but the other has an rb26 that uses a totally different base rom. this would save me the expense of purchasing multiple boards.
casner: (2007-03-10 01:28:28)
{{#if:OK85ZX|OK85ZX wrote:|Quote:}}
pardon the ignorance and point me where to read if necessary. [archived image: redface.png]ops:
what will the install work be? and will there be a limitation to the operating software version that is on the laptop used to adjust? and I don't understand if one will be able to data log without a wideband o2 (compared to the stock one). does anyone have pics of a finished installation just for reference? Thanx in advance guys.
(I've never tuned anything without a carb just to help explain but I am getting there as this ability is one of my new passions and I love to do everything myself whhich requires knowledge! [archived image: smile.png] )
Steve88t: (2007-03-10 02:13:47)
Socket the eprom, solder a couple of wires
Anything 98SE-XP should work fine. Vista I would be leary of.
NO
Yes, look at the nistune page. It's in this thread.
casner: (2007-03-10 02:58:50)
It's not in here steve, but this is the page I was thinking about': http://www.redz31.com/pages/fuel/romulator.html
I remembered it was on Jason's site. http://www.redz31.com for those that don't know.
darkhalf: (2007-03-11 14:35:06)
Installation is soldering connector with 4 wires to processor pins and then putting the USB socket in the ECU (i normally fit it where the diagnostic connector goes)
Software will run under Win98/WinXP which is what i daily run in on. PC has been Pentium 266 so resource requirements not high unlike other tuning software. It may run under Vista with FTDIs new drivers but I dont run that yet
  • I do have a romulator version (Rev2) for loading different rom images into an ECU only two of these available
darkhalf: (2007-03-21 08:36:30)
we will have another 10 of 50 boards ready this week.
after that i am waiting for USB Connector boards to arrive since I forgot to order some when getting all the bits .... doh!
those are going to be three weeks which will give us time to make all the connectors up for the remaining boards
I am currently looking into adding knock sensing detection and display into the firmware. I have found where the pulse and error flags get set in the code so just trying to see how the ECU uses them when pulling back timing. This way we can have a display for knock detection when it occurs
Also putting our documentation set together. Type 1 is for Z31
http://home.aanet.com.au/nistune/docs.html
It also shows what the software in its current form is capable of
darkhalf: (2007-04-19 14:39:09)
good stuff. try and keep the board in the pink anti static bubble wrap until you install in the ecu (as with any sentitive electronic components)l. we dont want a static spark to kill your board.... putting together a one sheet installation doc with this warning on it for future postings
1artworkz: (2007-04-19 19:15:43)
Gee, I forgot about that static thing. THANKS. However, I did re-wrap it in
the pink bubble wrap after looking at it.
QUESTIONS
NIStune_Type_1_Hardware_Installation.pdf does not specifically mention the
88 ECU is it the same as the 89?
My ECU has been modified by Jim Wolf Technology. See pictures below.
Are these red wire jumpers OEM or JWT? If they are JWT, do I need to
remove them for the NIStune board?
darkhalf: (2007-04-23 05:13:30)
probably can start posting these questions on our forum
those modifications look like they have been done aftermarket (by JWT) however relate to the analogue circuitry
the instructions for 1988/89 are the same. you have a 4 pin header connector silkscreen there on the circuit board, suck the solder out of the four holes and solder the connector wire to this
remove the JWT chip and plug the board in here.... then fit the USB connector where the diag pot is and you should be set
if you want the JWT maps on your board, you will need to read it with an EPROM programmer and open it up and copy them across with the software
mmw: (2007-05-28 17:09:24)
I'm currently having some difficulty with a 2002 Pathfinder's engine (my wife's car).
It has an intermittent hesitation at low RPM's and I would like to be able to get the CONSULT-II information when this problem occurs so I can possibly correct it.
3 Questions:
1. Are there any plans to develop NisTune to more recent Nissans like a 2002 Pathfinder (3.5 L) engine?
2. If not, is there any reasonably priced scanner which will provide me with full Consult-II information?
3. Is there a good internet forum for Pathfinders?
Thanks in advance,
Mark
darkhalf: (2007-06-01 14:33:58)
We do support some Consult II serial ECUs using the standard PLMS consult interface … on the Nissan Patrol for example
Consult II on later model Nissans may use Consult II over CAN which were are only investigating at this stage. Martin and Peter are putting the board together and I will add the software support for the board in this application. However that is many months away before even prototypes will be available. NIStune has been in development for about 3 years so far
ZDaddy: (2007-06-01 18:10:08)
Re:
I'm taking microcontrollers this quarter and I have access to a programmer. Gary, if you send me the chip I can read it for you and send everything back to you on a CD (aswell as your chip of course). I'm just learning about all this stuff so it's kinda like homework for me. 8)
darkhalf: (2007-06-18 01:49:14)
If you are having a specific problem with a board then email me directly, otherwise the forums can be used for general discussion (enhancement requests, queries etc)
The later versions of software required updated address files (for maptracing improvements, knock detection etc)
87-85turbo: (2007-08-01 21:37:07)
so how do i buy the nistune type 1 board?
Firehawk: (2007-08-02 07:05:46)
I know matt takes paypal. If you can't wait, I have an extra board for the late model single rom setups (86t, 87+). I also resocket the boards myself if anyone needs them done.
87-85turbo: (2007-08-02 23:55:47)
how much do you want for it?how hard is it to install?
Firehawk: (2007-08-04 05:52:08)
If you are not good with soldering, it can be a real pain. I will pm you for pricing.
ShamWow: (2007-09-12 21:21:32)
My curiosity has overcome my fear of being flamed to death:
Has anyone tried out the Nistune software on OS X? I'm Just trying to find out for future reference. I assume it can be made to work…
darkhalf: (2007-09-14 03:16:20)
info for ordering at end of https://z31library.com/extras_archive/www.nistune.com/
Steve88t: (2007-09-14 22:03:20)
You'll need to use a win32 emulator or virtual pc setup with win32 running in it.
Crazy: (2008-01-02 07:08:09)
Can NisTune read a knock senser?
darkhalf: (2008-01-16 13:55:40)
We are looking into using the TXS lite knock sensor feeding into the software. I've enabled reading the knock sensor input from the ECU. This gets sampled at about 9 times per second. Not sure this is fast enough for 'real knocking'
So I'm doing some tests with TXS vs regular knock sensor soon to see how it goes. As of current, no support officially available until I've finished
Steve88t: (2008-02-26 04:30:18)
It runs fine for me on vista ultimate 64 bit, xp pro, and 2000 pro.
gixxer750kid: (2008-02-29 06:09:39)
So For Nistune on later Z's will I need a Romulator? Or can I just plug into a laptop and tune? cause I have 2 ECU's I could use, I have a 84T(I Believe) and an 87NA, any advantages to one or the other?
Oh btw, Matt is the creator of Nistune if I'm correct just search Nistune on Google.... not THAT hard?
OK85ZX: (2008-02-29 07:03:31)
So… send an email first. You said it yourself. You know what to do, so do it. All the necessary information is listed on this thread.
hotshot172: (2008-04-22 20:45:03)
Holy crap that nistune website confuses the absolute crap out of me.....
I have an 87 300zxt. What the hell do i need to buy to tune it. What type of board? 1,2 or 3???
Should i buy an 88 300zxt ecu (manual tranny) to use nistune? i noticed the webiste said it would work with prior 88 ecu's but would be easier with the 88 ecu???
Can someone please break this down, barney style, for me.
I was spoiled by COBB tuning, where i just plug in a box to my ecu port on my subaru and start tuning.....
Chris86NA2T: (2008-04-22 21:06:09)
your kidding, right? Nistune requires just the slightest bit of though, but it really isnt hard to grasp the concepts. Try reading it again, but slower this time. COBB is geared toward "a.d.d." and "a.d.h.d." subaru retards. They make shit as simple as possible in order to sell the most product. Shit, my friend installed larger injectors and didnt tell the COBB equipment anything and it automatically adjusted everything. That doesnt happen with nistune. Your going to have to get the plug and play idea out of your head if you expect to get anywhere with a z31.
mike86z31: (2008-06-02 06:13:36)
would I need anything else but the nistune chip? like a romulator, keeping same kind of injectors.
darkhalf: (2008-06-27 07:49:41)
NIStune uses a daughterboard not a 'chip' so there is no need for any other equipment apart from wideband and laptop
Crazy: (2008-08-09 01:33:43)
Any word on Nistune being able to read a knock sensor?
340ZXTTAZ: (2008-08-14 00:32:21)
What is the highest HP that can be acheived when running the stock ECU and Nistune? Are the limitations even in the computer or in the MAF? I'mm about to invest in the upgrade but wonder if it would be better to just go with a standalone like Haltech.
FlawleZ: (2008-08-14 16:22:04)
While there are limitations, I seriously doubt your goals would exceed what NIStune can provide. The first limitation is the MAF which is easily replaced with a Z32 unit. If you're pushing more than ~600RWHP, you then have a couple different options. 1. You can obtain a higher flowing MAF that's supported, such as the Ford Lightning, or 2. You could delete the MAF entirely and run a MAP setup.
340ZXTTAZ: (2008-09-05 04:23:07)
So I just received my Nistune ECU with the Zener Diode installed for use with the lightning MAF. Thank you Matt for the quick turn around, the exterior was a little banged up but the ECU was fine. I installed tonight and the car started but ran rich. I also tried to connect to the ecu to check the parameters but the software said "Consult not available with this license". My questions are why will the software not connect with the ECU it is the latest ver.0.9.2.64 and I used the registration matt sent me int an email. Then why did it run so rich on start up? I thought the base rom was that of the stock Z31 that he copied from the ECU when I sent it to him. I'm thinking it has to do with the modification for the lightning MAF. Is it possible to modify the tune till I get the MAF installed?
OK85ZX: (2008-09-05 04:42:44)
Your best bet is to ask these questions on the Nistune forum. Also emailing Matt.
Careless: (2009-03-20 07:22:02)
I just want to add to this info.
There are some 486 Intel and AMD Pc's that use a version of Pheonix Bios and AMI Bios that has an executable flash.exe file to burn the on-board flash bios to the motherboard. Some are 28 pin, some are 30 pin, some are 32 pin.
If you possess one of these computers (as I have a 32 pin version), it is very easy to turn what would seem like a useless CPU into a very reliable chip burner.
In the bios, you could change the settings "Cache BIOS to Disk" or "Cache BIOS to RAM" (If I remember, this is BIOS Shadowing). It will then load the computer, load your boot disk with DOS on it, and load you into the A: prompt which you can then feed a disk with the flash.exe and the bin file that contains the proper Fuel Map/Nistune BIN file.
You can then remove the factory ROM chip from the motherboard without shutting the computer down, pop yours in, and go to town with flashing any BIN file you want on there.
I have an ECS K7VZA motorboard which is for an old AMD setup, and I've used it numerous times in the past to make HomeBrew mod-chips for the original XBOX console before they released various solutions to make this process easier and more configurable.
Just more info if anyone cares to pull their old junker out of the attic.
ShamWow: (2009-03-20 18:11:34)
Can you provide more information on doing this with Nistune? I was told Nistune and the Z31 ECU could not support a MAP setup.
HowlerMonkey: (2009-03-27 04:54:10)
Best information ever.
I no longer have my BK844usb so I will give this a shot.
Of course..........we could go full OBD2 with a late VG single cam ecu and just program it through the OBD2 port.
I'll let you guys know how that turns out.
FlawleZ: (2009-03-27 05:59:41)
[quote]mace350 wrote: [quote=Mike_GruiZinga][quote=FlawleZ] You could delete the MAF entirely and run a MAP setup.
I think hes thinking of megasquirt.
Uh…no.
Sure.
You can use a map sensor with NIStune if you use an HKS VPC for a Z32. Set NIStune to the Z32 MAF selection and voila!
darkhalf: (2009-04-03 12:28:21)
dont go on here much these days… but just letting you guys know we have Type 1 boards back in stock this week :-D
Big_E-Dog: (2009-04-07 09:50:42)
ok i gots the nistune in today and i located the large chip to be removed was wondering where (in pics) does the 4 xtra wires go been loking but found nothing and can i run it for a while until i can get to the dyno shop??
DeleriousZ: (2009-04-07 17:36:32)
it's, or it should be, detailed in the install guide.
Big_E-Dog: (2009-04-12 07:42:53)
ok so i read the manual a few times before junping ito this, using my 87 maxima ecu just to see if it works. so i removed the eprom chip installed the socket, soildered the 4 wired to the 6802 processor. placed the old rom chip in the socket and it still works so im like sweet i did it right. then when i put in the nistune board in..... nothing..... the chip in the center of the 28pin outline (on the nistune board) gets hot(noticed this as i pulled it off of the board) so i was like DAMN how could i fubared this. went over the manual again checked solder points all good. placed in the old rom chip and it still works, so whats the deal is the board that i got defective??
862sik: (2009-04-14 05:51:15)
i was trying to find some info on nistunes site about a federal car. i understand it can go one way, but can it go the other way…in other words, can i use a non federal ecu in my car?
i want to have my stock federal ecu as a backup just for the heck of it and i can get another ecu at the junkyard, i think i saw a 86 turbo, and 88 turbo and a few 87 NA's and alot of 86 na's.
i think there was a few things like EGT sensor that i dont ahve and things like that.
MADMIKE: (2009-05-05 05:01:01)
I had a quick question. Is it still desirable to get an 88T + ECU, or can should I just use the stock 86T? I had hear you can load up images from the other years to Nistune but wouldn't you still need the same style o2? I'm sorry for the noob questions, I am just a tad overwhelmed.
My last Z was totaled before nistune really was an option so I have ALOT of catching up to do. My new Z is an 86T 5spd.
Thank you for the help.
Mike
862sik: (2009-05-05 07:46:31)
do a little searching, i have no idea but i think you have to use resistors for the fuel injectors.
type in 'nistune' i flew by them a few times. and the forums on nistune has hecka info
DeleriousZ: (2009-05-05 15:03:29)
i'd get the 88 ecu just for the simplicity of soldering those 4 wires lol. no messing with dropping them onto a chip, just put em right into the pcb and be done with it.
i'm not sure about the 86 ecu but i know the earlier ecu's had problems with a lean surge condition, i am also unsure if nistune can get rid of that, but it wouldn't be worth it to try and find out.
the one thing you run into with the 88t+ ecu's is the daughterboard for the detonation sensor, which is a pain to work around when installing nistune.
FlawleZ: (2009-05-09 20:07:57)
I believe the 88NA ECU is still the most desirable ECU for NIStune since it is essentially the 88T without the daughterboard.
MADMIKE: (2009-05-31 00:29:05)
Ok just did a little more research. The problem I see is that the 02 sensor is different.
If I was to take use a 89NA board, I would need to re-wire and go with the larger bung for the Zirconium o2. How much of a Pita is the daughter-board on the Turbo ECUs? I've read that the Turbo Proms can be swapped onto the NA board, can't I just remove/disable the daughter board? Is there an advantage to running with the Titania o2 over the Zirconium? Anyone have a decent photo of the guts of an 89T ECU so I can see what I have to work with?
Just trying to shed some light on all of this.
F/A 300: (2009-06-09 04:41:28)
Removed due to me being a dumb a$$.
Also anyone that needs these soldered in. I am a solder tech in the Navy. I will do it for you for free just have to pay shipping here and back. Once I get mine set up I can even have a base tune set up if you would like.
DeleriousZ: (2009-06-09 04:49:32)
using this instruction form?
http://nistune.com/docs/NIStune_Type_1_ … lation.pdf
see pg. 12 (of 12?)
and no, you leave that other daughter board in, it's for the detonation sensor
Big_E-Dog: (2009-07-04 07:54:42)
ok i got some vg30dett injectors and was wondering if they were just a drop in and change the injector cc in nistune.
in ither words are the impedence the same??
F/A 300: (2009-07-04 23:46:31)
http://www.redz31.net/pages/fuel.html
I'm almost 100 percent positive that the Z32 are high impedance.
If you can't find something on here check yahoo or google.
FlawleZ: (2009-07-07 14:13:59)
The Z32 uses high impedance side feed injectors. They are not a direct fit for OEM SOHC VG30 fuel rails.
michaelp: (2009-07-10 05:11:56)
{{#if:Big_E-Dog|Big_E-Dog wrote:|Quote:}}
They appear to be the same or similar type the pathfinders use, but I can't verify since I don't have any Z32 injectors…
New 2 Z: (2009-09-28 19:32:44)
alright I was doing more digging and this IS the best bang for the buck but I'm a little confused about it
whats the difference between board 1, 2, 3, and 4? aren't they all the same? or no? and it says' AUD. is this coming from Australia or what?
also would nistune work on a 85 turbo ECU?
NissanEgg: (2009-09-28 21:24:16)
I know that J30 Maxima use the same injector o-rings as the SR20's and VG30DE/TT. So it is possible the Z32 injectors will fit.
The R50 Pathfinders and Quests use the same injectors which are smaller in diameter and use different o-rings as listed above. This means those injectors will not fit the R50 or V40/41
FlawleZ: (2009-09-30 07:18:48)
The information is available on the NIStune website. But in short, the different types are merely revisions and hardware changes to accommodate the different types of ECUs each car has. Once installed and plugged in, it works essentially the exact same in every single car. You basically just specify to Matt when ordering which type you need.
Yes, its coming from Australia unless you purchase one locally through one of the distributors or retail stores that carry NIStune.
Yes, NIStune will work on ANY Z31 ECU.
Wht87z31t: (2009-10-31 08:50:40)
Ok im geting ready to get my Z back on the road. Im wanting to go with NisTune. I just dont know what setup that I need to get. Please help :-?
Russ84na: (2009-10-31 23:31:40)
Go to this site and read it cover to cover. https://z31library.com/extras_archive/www.nistune.com/
Then either pull your ECU and send it to Matt to have Nistune installed or find a second ECU and save you orginal for a back up. Once you are sure that the replacement you got works send it to Matt.
When you get it back, plug it in and find someone to help you tune it. It is really simple.
Windzer: (2010-01-26 19:31:44)
Question. I have an 88turbo and i'm going to get Nistune put on an 86T ECU. If I should at a later point move to high impedence injectors, how hard is it to swap the Nistune to the other ECU, if it is even possible? Is it just unsolder and resolder kind of deal?
Also, who are some local retailers of the NisTune hardware and does anyone know if they keep the parts for the Z31 in stock, or is it basically the same as ordering from the guy who developed Nistune?`
NissanXRMA: (2010-02-02 02:46:55)
If you change impedences, you don't have to change the ecu. You can use drop in resistors if you have a high impedence ECU on low impedence injectors or its fine if you have a low impedence ECU on high impedence injectors. Theres no need to swap nistune from ECU to ECU.
Talk to matt at NIStune about ordering.
Windzer: (2010-02-08 18:56:36)
This is true, but it's harder to tune the injectors correctly due to the resistors. Since I have one of each, it is easier for me and better for peace of mind to just swap the nistune to the other ECU.
Careless: (2010-04-10 16:21:16)
steps:
1) remove nistune from current ecu.
2) follow "nistune installation" instructions to install nistune to the second ecu.
simple as that.
hypcodiiihop: (2010-04-23 23:04:19)
Just incase anyone is looking for a stateside vendor, I went through http://www.autovaughnperformance.com/
Excellent customer service and pricing. I hate soldering/electrical work in general, and these guys only charge 430 return shipped for a type 1 board, installation, and user license. Great deal and great people with very fast turn around compared to going direct through nistune.
ZMIKEMAN: (2010-04-29 01:34:06)
Thanks for the link.
I have two ECU's I could send in, one auto 84T and one Manual 84T ECU. The car was an auto originally but is currently running the 5spd ECU. Both work well however I was thinking I might one day build the car for the dragstrip with a paddleshift driven automatic. I wasn't sure if there were much differences but figured I may need the auto ECU's capabilities in the future for TPS so I would send it in instead of the 5spd? Any thoughts?
88sinZ: (2010-04-30 05:06:36)
excellent, i've been holding off so long not wanting to deal with international shipping now i have no excuse!
badboyz31: (2010-06-17 23:06:49)
Finally got my nistune install all done and I must say this is fun. I got to play with it a little at work and now I can't wait to get home!
thanks hypcodiiihop, I to recommend auto vaughn performance, andy is a great guy and helped me every step of the way!
Grr: (2010-06-18 04:02:07)
agreed i just dealt with andy at autovaughn, that guy is first class and i highly reccommend him. He said if I am on the dyno and having problems it would be ok to call him even if its late for help. great guy
badboyz31: (2010-06-18 15:32:55)
Is there anyone else besides me who has a type 1 board installed on an 86 na ecu?
james: (2010-06-19 00:50:10)
I have type one installed on an 85 ECU,
Does anybody get the error "extended consult not available with this license"
I have purchased the software from Matt, got a product key and all.
When i had it installed on my laptop( vista ) it was fine but on my garage desktop pc with win xp it gives me that error.
Rick88ss: (2010-11-22 18:02:31)
Is it posted anywhere in one spot which MAF is needed for X amount of power?
How much whp is the stock MAF good for without any mods to it or air bypass?
340ZXTTAZ: (2010-11-23 06:19:55)
400 + on stock maf, Z32 ~500, Cobra ~500 and the Lightning ~700.
88sinZ: (2011-01-10 03:35:44)
Regarding system requirements and performance, what is par?
pretty much if i bring my vehicle to a tuner would i be better off letting them use their Dell Intel Core2 duo or whatever junk it may be. Or would i be better off bringing an i7, high RAM equipped laptop? required ports? serial for the 02 input and USB 2.0? any others?
-Nistune 88 fed 5sp
-Innovate WB 02
shromy: (2011-01-10 14:43:23)
Either will work fine, The requirements are small like 400mhz, 1/4 gig of ram.
88sinZ: (2011-01-10 15:57:59)
So the time between the ECU picking up signals and the computer reading and displaying them is not very demanding on the system?
shromy: (2011-01-10 16:11:10)
No it is not. Dont get me wrong faster is always better, but it eventually can only send/read so fast.
Found it.
16. What are the minimum requirements for NIStune
NIStune is written to be as lightweight in system resources as possible. We recommend using laptop with:
- Pentium 500Mhz + recommended running XP, Vista or Windows 7 (32 bit versions)
- USB 1.0 port (if using Type 1 board or USB Serial converter)
- Serial port / USB Serial Converter: Consult Connection (Used with Type 2 board)
- Serial port / USB Serial Converter: Wideband data display and logging
srsands: (2011-02-15 14:20:29)
Hey guys new to the forum and just starting to learn and research my options for a fuel managment system. I have a 70 Datsun 510 with a vg30 from a pathfinder. The motor has stock internals with headers and MSD ignition system. I initially wanted to purchase Nistune for my tunning needs but read some info on the web that the product does not support my ECU. I then switched my learning interest to Megasquirt. I recently was told that guys here are using the z32 Nistune on the Z31. Anyways thats not my case either. I have a pathfinder ECU. The numbers on the ecu are 37 MECM-V180 B1 0120. Can anyone verify Nistune has a product that I can use on this ECU or should I just stay focused on the idea of Megasquirt or JWT (even though I dont want to mail it everytime I add a performance mod). My plans are Holset H1E, Intercooler and 440cc injectors or larger. Please let me know. Thanks
michaelp: (2011-02-15 14:41:43)
You could find a Z31 wiring harness and ECU and get Nistune for it [archived image: smile.png]
Bernardd: (2011-02-15 15:59:46)
3
88sinZ: (2011-02-26 17:48:14)
HOW DO CONNECT NISTUNE LC-1
300zxturboftw: (2011-08-03 03:48:09)
Plug LC-1 in. Set in preferences which com port it's on. open AFR gauge in nistune.
/time
KiileZ: (2011-08-22 04:40:25)
Okay so I got nistune installed of my ecu. If I want to use the z32 maf do I still need to remove the resistors and what not? Its an 86 NA ecu.
88sinZ: (2011-08-22 15:54:16)
yes
DMANN: (2011-08-22 21:16:28)
I'm thinking about getting Nistune…But, have a few questions.
First I've been with the romulator for quite sometime.
I've got a really good tune now.
Is it possible to just download my tune onto the Nistune and be good to go.
If not what are the other options to keep the tune I have and get it onto Nistune.
Russ84na: (2011-08-23 01:16:55)
I started using Nistune when it used a Romulator. You did the tune and then burned it onto a chip and inserted in the socket. So I would think that if you have the bin file on the computer you should be able to load it into the nistune software and then upload it to your ecu.
wally1589: (2011-10-15 04:42:18)
is there a certain limit in hp, boost, or with nistune type1?
and, can it read any MAF SENSOR? or, is a matter of just connecting the wires of the new MAF?
MADMIKE: (2011-10-24 08:35:33)
So couple of quick questions:
Can Nistune run a Map setup?
Can you Nistune read 2x Mafs, 2x o2, 2x widebands?
shromy: (2011-10-24 13:53:04)
No, no,and No last I checked
shromy: (2011-10-24 13:55:10)
No not really and yes any maf as long as connected properly. Maf is a big factor to the hp/boost ability.
NizmoZ31: (2012-02-27 20:20:58)
Is the NisTune chip compatable with a JWT ECU? or worth it or nessecary or a good idea ect, ect…
MADMIKE: (2012-02-27 20:42:22)
sell the jwt get a nistune
NizmoZ31: (2012-02-27 20:57:15)
Roger that, appreciate it man. [archived image: smile.png]
wire: (2012-07-03 13:51:11)
Once you have tuned your setup properly with nistune and have a reliable runner, is it possible to pull the changed values and burn a prom to run the ecu with your new preferred tune?
Some classes of racing only allow a stock ecu with nothing extra connected to it but do allow burning a new prom.
G-E: (2012-07-04 06:50:43)
But nothing will be connected to it, it's all inside the ecu
shromy: (2012-07-04 15:01:53)
Yes it is possible to do so.
MY1PATH: (2012-07-04 22:33:38)
[quote]G-E wrote:
{{#if:wire|wire wrote:|Quote:}}
Some classes of racing only allow a stock ecu with nothing extra connected to it but do allow burning a new prom.But nothing will be connected to it, it's all inside the ecu
exactly, and even if the internal daughter board wasn't allowed, I highly doubt they are gonna make you pull out you ecu and open it just to see…
Black 89Turbo: (2012-07-11 22:42:28)
I still have not got the car to run correctly. I have not messed with it in a couple of weeks but going to start tomo i think. If anyone wants to follow along:
http://msextra.com/forums/viewtopic.php?f=134&t=44897
This is the biggest headache i have ever had with any standalone EMS. I would not recommend it for a z31 personally.
Careless: (2012-09-15 00:43:38)
lulz. nistune brah. why ms?
WarOnFlesh: (2012-09-21 21:46:06)
G-E: (2012-09-21 21:48:43)
Matt specifically said he wouldn't implement any serious anti-theft unless piracy became an issue… and I think we can all agree his efforts are best put towards the tuning part not some ganked piracy locking
Black 89Turbo: (2012-10-03 07:01:55)
MS was choosen for the platform. It has many Inputs/outputs, you can long damn near anything, you have antilag, 2step, 3step. Can run many injectors, fully sequential, Multiple coils, Get rid of MAF. Cableless tunning(bluetooth), SD card input so you can save your tunes,datalogs ect and look at them whenever you want. Essentially i can do anything and everything with it. It can be installed on pretty much any car. For $602 bucks for MS3/V3.57, wiring harness, ect. I couldnt pass it up. The down side is you have to wire the car yourself (Not a big deal, heck the wiring harness wires are labeled for you). Not many have Utilized it with a vg30 engine so R&D is still on the platter. No base maps. I think the biggest down side is the FSM. There is so much misinfomation it causes you to go crazy because your believeing what your reading, but its totally taking you off course blindly. After all i got the car running pretty decent. Put at least 1000 miles on it. Ive had it on 35psi+(boost gauge stops),22-25 psi regularly, timing is locked @ 10degrees :lol: ....Got EGT? Currently, there is no clutch and the diff went by by. Looking for a shell to swap everything over. The motor is still holding strong, compression is @ its usuall 90psi-100psi across the board. Hasnt changed in years :mdr
jaqattack02: (2013-01-21 02:13:13)
Has anyone used a pro sport wideband with a nistune ecu? Anything I need to know to get it working? I didn't see it listed in the documentation.
Axel kain: (2013-01-21 05:30:39)
im planning to use it on mine and brian's, it has 2 optional outputs. with different voltage scales. should be in your paperwork, telling what the scales equate to. one I think it 0-1V other is (I think) 0-5v. then to figure out what nistune scalers are… part of me wants to say theyre selectable.
jaqattack02: (2013-01-21 13:34:30)
I'll see if I can dig out the paperwork for the wideband tonight. I'll try to document how to get it working and post it up here.
Augustus Maximus: (2013-07-05 14:29:21)
According to Nistune, once you come up with a tune you like you can burn the image permanently to EPROM. Does this not render Nistune null and void thereafter?
And if not, do you have to reload the damn thing everytime you start the car.
DeleriousZ: (2013-07-05 15:34:54)
Once you burn the eprom, you no longer need to connect the laptop to nistune to drive the car. You need to leave it installed, as the map is contained within the nistune card. You can take the map you made and flash it to an eprom chip, then install the chip if you wanted to get rid of nistune afterwards. I don't know if I'd recommend that though!
Z-31Turbo: (2013-07-06 15:14:28)
Since I'm having some trouble to connect my Nistune board, could I use Nistune to change the injector (259CC to 450CC) and then save the .bin, burn it to a chip and put it in my ECU for now?
Does the .bin saved from Nistune include all the required address and data to run the car?
Augustus Maximus: (2013-07-08 22:23:28)
And if you burn to eprom and later uograde to bigger injectors? Until my understanding is clear I go through the hassle of loading up each and everytime I start the gotdamn car.
G-E: (2013-07-20 02:19:21)
Why can't you guys understand that the whole point of nistune is that it's not an emulator, it's a repogrammable rom chip, once programmed you can leave it alone
Careless: (2013-07-20 05:03:14)
yes. you can burn the .bin file to someone's eeprom using a burner and retain the tune and the drivability the same way as if the nistune was not hooked up to a laptop.
infact, i'm surprised someone hasn't made a better tune than the JWT450 and sold those yet at as replaceable chip.
Parker: (2013-07-20 05:50:15)
You need to buy the DLP Design A/D converter. You connect your 0-5v analog output to it and it outputs a digital signal to your PC via USB for logging. The converter is $30 and there's a link to it from Nistune's FAQ page in the list of supported wideband units. Any wideband with a 0-5v analog output will work with Nistune using this converter.
G-E: (2013-07-20 06:18:00)
Unless you use something like innovate over serial/usb
Parker: (2013-07-20 15:55:51)
Well yeah, if you have a wideband unit that comes with its own datalogger, you wouldn't need the DLP Design thingy. I just meant that any wideband sensor that outputs a 0-5v analog signal will work with the DLP unit.
Augustus Maximus: (2013-07-21 03:32:16)
My question is unanswered…I'll direct it to the maker himself.
Parker: (2013-07-21 04:59:46)
Careless and GE both answered it. Nistune's people will tell you pretty much the same thing. Nistune's software runs on your laptop and you connect it to your Nistune daughterboard-equipped ECU; once you get a tune you like you use the software to burn it to the NVRAM in the Nistune daughterboard and it becomes a standalone. You can disconnect the laptop after that but you still own Nistune. If you change injector sizes you can hook up the laptop again, run Nistune, re-tune, re-burn, disconnect the laptop again. You can do this as many times as you want.
Think of the tune like a can of paint and the laptop running Nistune as a paint brush. Once you take the paint brush out of the can, clean it and put it away, it's not like the paint disappears from your walls. When you want to paint a different color, you get the paint brush out and use it again until your wall is painted, then you clean it and put it away. The new color still stays on the wall, and the paint brush doesn't disintegrate or become non-functional after applying a coat of paint.
I apologize if I come off as patronizing; it's not my intention. Just trying to come up with a basic analogy.
Careless: (2013-07-21 05:56:50)
your question has been answered.
when you BURN the image after tuning it, it stays on the chip that is on the nistune board.
you do not need to use the nistune software after.
if you remove the nistune board, you are removing the chip that houses the ROM/BIN for your tune.
if you want to remove the nistune board from your ECU to sell it but you want to retain the tune, you have to get someone to burn a 28pin EEPROM just like the one that was taken out of the board to install nistune. You take your bin file you edited (basically your tune), burn it to the new chip, insert it into the socket where your nistune was, essentially making it a stock ECU again, but with a different program/tune.
The PROM is basically a chip like a CD-RW disc. You burn it, and the files stay on it until you reburn it.
Nistune is essentially a computer with a writer that allows you to burn the CD-RW/PROM.
The ECU is basically a CD player with only minor write capability (i.e. clearing codes).
You dont need to boot up the computer (nistune) to load up the CD (eeprom) if you have the disc in the player (ECU).
and i guess your car would be the speaker system or monitor. lol
G-E: (2013-07-21 05:59:29)
Parker, you gotta cut back on the shrooms, seriously, paintbrush?
Careless: (2013-07-21 06:04:00)
i thought it was a good analogy. but we're talking about electronics so I used CD-RW's as a different example. lol
edit: you got a problem with shrooms? they awesome.
Augustus Maximus: (2013-07-21 08:10:12)
Got it…
Parker: (2013-07-21 14:04:59)
Dude I've worked 30 straight 12-hour days where I have to get up at 5am and the fucking sun doesn't go down until 11:30pm so I'm lucky to get 5 hours of sleep in a night. Cut me some slack, would you? [archived image: tongue.png]
Careless: (2013-07-21 19:16:27)
well in that case, maybe you should take shrooms. then you'll be saying "5 hours is way too much fucking sleep broooooooo"
Parker: (2013-07-21 19:22:00)
Hahaha. I've tried quite a few different recreational substances, and I've found I enjoy the mood-altering kind a lot more than the perception-altering kind. Plus, they have this annoying zero-tolerance rule for alcohol and drugs here. They're finally letting me out on Thursday.
Careless: (2013-07-21 19:39:12)
if you take enough/right amount of shrooms to put you right under the hallucination state so that you don't have any altered visuals, you will definitely feel as if you're in a mood-altering state. i actually like that feeling way better. lol
edit: i am not a drug pusher!
FlawleZ: (2014-05-05 19:42:52)
For those of you looking to install yourself, Matt has posted a detailed walk thru video here:
https://www.youtube.com/watch?v=WowQQs-GVIM
Also, can we make this a sticky again?
Z_Karma: (2014-05-05 20:55:38)
Stickified.
That was really a great how-to video.
Really straight forward.
He was using a professional de-soldering tool.
If all you have access to is one of these:
you can nip the pins of the old Eprom with fingernail clippers
(if you don't have a small set of dikes) and remove the chip, then
with a soldering iron on the underside, suck the solder (and pin remnants) out the top.
Augustus Maximus: (2014-07-19 16:39:14)
I used a Radio Shack desoldering iron without the acetone step.
[archived image: pRS1C-2160644w345.jpg]
Easy as pie.
Axel kain: (2014-07-21 13:27:05)
So my friends board flipped out when on the dyno, MAF, RPM and injection control had glitched, then somehow burned into the board. - found this out after sending it back to Matt. he corrected it, repaired a pin for me, and is on the way back now, for $25. excellent customer service! Says it's working properly now!
I had swapped his board for mine, to realize it was a hardware/major software issue with his. hopefully all is well now!
Axel kain: (2014-09-23 13:24:23)
Dealing with Nistune again, trying to get my friends car to run right. I started with a base 88 map, corrected for 560cc injectors and Z32 MAF. it will fire up and run ok. but watching AFR's it's rich. start to adjust latency (no idea what it should be since we cant find a spec for RX-7 560's) and K to get it to lean up some. when it's around 14 or so it starts running rougher. if I hold the throttle at a higher RPM it richens up again, I adjust the map, etc to get that section to make the O2 read 13-14 or so (this is all while sitting still), I can actually feel it miss, and stumble at times, as the wideband swings between 13 and 15… Im wondering if either it's just my latency and K being incorrect, or some other setting, or if we actually have bad/clogged injectors. They came from Evolution Injection (my brother got from him too, and are great) flow tested, etc.
any thoughts?
FlawleZ: (2014-09-23 13:57:08)
My approach is simple when setting a base tune:
Load a stock basemap in NIStune.
Adjust for injector size.
Set a flat AFR across the map.
Adjust the K value until you match the AFR (or as close as possible)
I then adjust the map accordingly to match my desired AFR at a given RPM
If they're new or recently flow tested, they should be OK.
Are these the same as the ND 560 Evo 8 injectors? If so latency should be .048
amreboot: (2014-09-23 14:06:41)
This is exactly how I got my running tune done.
I was able to drive 1.5 hours to the tuner's shop without issues.
Axel kain: (2014-09-23 16:39:23)
I'll try this, set the Injector Latency to 480, and adjust maybe 2 or 3 columns to a set AFR and see what I can do with that, adjusting the K to match, at least in stationary trials. Thanks.
Im also talking to Matt about getting the Innovate wideband to consult with Nistune properly…
Axel kain: (2014-09-23 18:46:35)
also, did either of you notice the AFR's being jumpy or skiddish? Using Innovate LC-1 I believe it is…
FlawleZ: (2014-09-23 22:14:55)
Some fluctuation is normal. A large variance is typically either incorrect latency values or a hardware problem at least in my experience.
88sinZ: (2014-09-24 03:22:25)
are you going to visit the place in RVA for a tune? lmk how they do.
Axel kain: (2014-09-24 13:16:46)
Been dealing with Matt Shue who tunes at Momentum autosport in the Hanover Air Park… nice knowledgeable guy, I have a feeling it might be my O2 needing to be recalibrated, and since the gauge isnt communicating properly, im going to have to do the old hard wire recalibration method…
jaqattack02: (2014-09-24 18:25:20)
This is who they are using for the tuning. Pretty sure it's his first Z31, but he's done a number of Z32s and other Nissans before. http://www.shuetuning.net/
88sinZ: (2014-09-25 02:42:34)
Small world, i did some aviation training at HOVA
I ran into some issues with the RS232 to USB drivers giving NisTune incorrect feedback. Do you have that resolved?
Correct distance from turbine outlet, etc?
Axel kain: (2014-09-25 13:10:26)
well, it's in a roastin' down pipe, so i'd say its relatively in a stock location. I threw a video of the issues on the FB page… once I figure out the best way, I'll put it on here too. when I held it at a steady throttle, sitting still, at around 3500 the AFR would literally bounce from 13-16. almost blip to 16…16+. makes me wonder about the injectors, being that at higher RPM it does it more/worse.
Axel kain: (2014-09-29 13:20:28)
OK! so, in talking with Matt, I got the Innovate working in Nistune! I found the TPS is out of spec, so I disconnected it for the time being, as well as swapped in an actual Z32 MAF just to test, noticed voltages consistent with the HPX. ruled that out.
SO, in testing now, I have a DEAD spot at 2500 RPM or so. it dumps full lean at that rpm, above and below it runs awesome!!
Talking to Matt about that, believes it's an image issue, apparently the chip thinks it's a NA (didnt know) 88-89 setup (I knew that) in an 87 NA auto ECU. More to come as it progresses, I think this may have just happened to be a perfectly bad situation for us…
Rick88ss: (2014-12-22 20:28:56)
Did you finally get it working correctly?
Axel kain: (2014-12-22 21:43:33)
updated my own issue thread. but no, issue has not be resolved, even after a reflash from autovaughn. I DID swap my well running ecu into the problem car, and just adjusted the injector K to suit the larger injectors, and it still does the exact same issue. ignition system, other than the cap and rotor has all been swapped out/tested. (cap and rotor are new/non leaking/only have a few miles on them)
Allout: (2015-04-29 23:00:16)
If anyone is looking to buy a Nistune, the US dollar is sitting pretty good compared to the Australian dollar.
Last year - 260 AUD would cost you around 240 US Dollars. Today, 260 AUD would cost you around 205 US Dollars.
