Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/t3 turbo
Imported from Z31Performance.com Forums{{#if:86VG30ETURBO| — original post by 86VG30ETURBO}}{{#if:2012-03-07 00:16:04|, posted 2012-03-07 00:16:04}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/17162-t3-turbo.html|
86VG30ETURBO: (2012-03-07 00:16:04)
i have an 86 300zx turbo an wanted to know the specs on the original t3 turbo?
NissanXRMA: (2012-03-07 00:18:49)
Small.
michaelp: (2012-03-07 00:19:17)
Did you even try searching?
Its a 60 trim compressor with a .63 A/R hot side.
NissanXRMA: (2012-03-07 00:26:02)
are you new here?
86VG30ETURBO: (2012-03-07 00:30:37)
thanks for the info i did some research just wanted to make sure.
86VG30ETURBO: (2012-03-07 00:37:29)
what would you guys recomend my power goal is 350whp i was thinkin of gettin my t3 an makin it a hybrid t3t4. what setup would be good for quick spool up time an enough to reach my goal power?
Modds i have: 3 catless full exhaust, fmic, ebc, 450cc dsm injectors, z32 maf, 255lph walbro fuel pump, an waitin on nistune.
michaelp: (2012-03-07 00:47:12)
get the stock t3 upgraded to a t3/t4, it should spool pretty quick and make the 350hp you want.
86VG30ETURBO: (2012-03-07 00:50:32)
i heard that a 50trim t3/t4 would be a great turbo setup can my stock be upgraded to a 50trim? an what turbine size or upgrade would be a good one?
z-flash: (2012-03-07 01:23:02)
Required reading:
http://www.redz31.net/turbofaq/turbo.faq.htm
Helpful links:
http://www.automotivearticles.com/Turbo_Selection.shtml
https://z31library.com/extras_archive/www.mygen.com/ … 20Maps.htm
onefast87: (2012-03-08 02:26:23)
how many MM is the compressor on a T3?
aceman: (2012-03-08 02:33:03)
This faq was outdated when it was written 7 years ago.
z-flash: (2012-03-08 02:58:42)
^Yes, I agree, Aceman^
Some turbo specs:
http://www.ztechz.net/id1.html
http://fc3spro.com/TECH/TURBO/tmodels.html
